S-tec Motorsports »
https://forums.nicoclub.com/s-tec-motorsports-u94813.html
Wed Oct 17, 2012 9:16 pm
Shifter is easy to fix if you have a mig welder, just cut the shaft and put it at an angle.
The mount is not as easy, you pretty much have to make one. You can start with the stock mount and weld a plate on it, it is not that hard to make. Please do not do the one bolt per side trick, it does not work out so well.
