RBZ32 »
https://forums.nicoclub.com/rbz32-u143626.html
Sun Sep 20, 2009 12:27 pm
I'm running out of ideas. This started on a drive home from Seattle. On the highway the car suddenly was way down on power and I could tell there was a misfire from the sound. Then it went away after 5 mins, but then a few miles later it started again and hasn't gone away. I changed the spark plugs and used a smaller gap for them and the problem stopped for 3 days. Then it started again. The misfire happens at all RPM's, cold and warm engine temp. I checked the coil packs and found that #6 is the problem. Cleaned all the coilpacks, didn't help. I changed the coil packs around and #6 still misfired with a different pack on it. The pack from #6 that I moved to #1 worked fine there, and the pack from #1 that was working, now wasn't on #6. I then checked the spark plugs again and found they were ok. Changed the #6 plug with a new one with proper gap and still misfires.
Anyone have any ideas what else to check or could be causing this?
