Rb25 Mckinney motor mounts s14 installlation problem need some help
nyc240sx
Car: 1995 Nissan 240SX SE
RB25DET series 2
I bought a set of mckinney motor mounts and transmission mount i found out they was one of the first ones made and the guy said they work with s13 and s14....I mounted them up but they sit flat straight i was thinking they have to be on a slight angle since the engine brackets are angled i guess i didnt get the engine in yet so iam kinda lost here does anyone know how they supposed to be mounted or have any pictures....Thanks
jdmae86
Car: S14 - RB25DET SII
they should not lay flat... you prob have something messes up
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
pictures = 1000 words
lets see what you are working with; could very well be end user error
FAST-DATSUN
Call us direct 951-304-9300. Maybe you we sold the wrong one's We can email you prctures of what they should look/fit like...We make 3 different kinds RB20- RB5- Rb26 all fit different to best fit the motor/turbos set up..
Modified by FAST-DATSUN at 8:36 PM 8/20/2008
nyc240sx
RB25DET series 2
ok thanks i'll give you a call....can you also email me the pictures to: [email protected]
FAST-DATSUN
OK what motor are you putting in ?? and is you car a S13 or S14
nyc240sx
RB25DET series 2
The motor iam putting in is RB25det its going into S14
FAST-DATSUN
sent you a email with the pictures
FAST-DATSUN
send me some pic's of the engine block adapter that bolt to the block and the mounts. We seeing some engine with RB20 and RB26 style adapter, because the engine was already a swap in Japan.....
mdwiemann
Car: Sylvia (S14)
Bringing this post back alive, hopefully you found a fix, as I am having the same problem on my S14 with RB25DET motor. Bought the S14 motor mounts and they sit more flat than angled like the engines mounts.
Hoping someone can email me old pics or give me some insight as to how this was fixed, it looks like about a 10degree difference in the mounting alignment.
email [email protected] if you have some suggestions, sorry no pics atm
FinkenS14
Car: 1995 Nissan 240sx S14
They should sit like ths
My RB25 into my S14...
FerrariTruck
FinkenS14 wrote:They should sit like ths
hey bud, your mounts look like they are sitting to flat.. then again i also had issues with my mckinney mounts lining up right.
i have rb20 and my mounts didnt sit like that and the bottom piece of the mount is like a 1" from the frame so i can bolt it up
FAST-DATSUN
on some cars your will need to add spacers(washers) to fit between the saftey strap and the crossmember to take up the space.Call me for any problems. Mack
FAST-DATSUN
nyc240sx wrote:I bought a set of mckinney motor mounts and transmission mount i found out they was one of the first ones made and the guy said they work with s13 and s14....I mounted them up but they sit flat straight i was thinking they have to be on a slight angle since the engine brackets are angled i guess i didnt get the engine in yet so iam kinda lost here does anyone know how they supposed to be mounted or have any pictures....Thanks
I assume there used, if there some of our early ones, we gone through many changes in 15 years on the mounts. Call me and we can help..Mack
FerrariTruck
thanks, do you have an email so i can send you pics? I was even think i might just need a 1" spacer or so and a new longer bolt.
dizzywithsunstroke
Car: 1995 Nissan 240sx w/ RB20DET and 1997 Nissan Hardbody
you have them backwards. as in left is on right and right is on left man. try to switch them.
FinkenS14
The motor fit just fine, and the trans cross member lined right up, im not complaining.
The motor fit just fine, and the trans cross member lined right up, im not complaining.[
FAST-DATSUN
Call me......... Mack 951-304-9300 I will help you...
