wakotow »
https://forums.nicoclub.com/wakotow-u117588.html
Tue Oct 27, 2009 3:01 pm
-stock will work just fine (search 'holset on rb20 notes')
-if it's really, really close you can grind the compressor back
-or you could cut the flange off, then cut the collector at an angle then weld it back on, that shouldn't affect it's flow capabilities
make sure you have a good wastegate or you won't be able to keep that beast from spooling.
what turbo blanket is that on your hx35?
