RB25 Makes weird noise at start up
N!SMO SILVIA
Car: 95 240sx
RB is running smooth. It's like gliding through air The only problem is that when I start it up, it makes some weird high pitch noise. I know its not the started because I changed it about a week ago. People have told me it does not hurt the engine but its just the noise that I wish would go away. Anyways, here is a video of what it sounds like.
http://youtube.com/watch?v=s3e2QudhDYI
Shocker
Car: 89 240sxHB rb26/30
video is private there..
N!SMO SILVIA
Car: 95 240sx
Shocker wrote:video is private there..
Oh great. Sorry about that. I just fixed it so you should be able to watch it now.
Andyb2637
Car: 240sx
If The bolts are they could be putin a little pressure on the flywheel..could be the problem, but really shouldent affect anything
N!SMO SILVIA
Car: 95 240sx
Andyb2637 wrote:If The bolts are they could be putin a little pressure on the flywheel..could be the problem, but really shouldent affect anything
Ah yeah I've heard that before as well. Hmm...gonna have to check on that then. Any other ideas on what it could be? Just want to make sure before I go spend money that I don't have
Andyb2637
Car: 240sx
Oh yea did you check the teeth on your fliy wheel? Your flywheel could be warped alil? it could also been your starter you could take it to autozone to let them test it(its free) so yea id do the starter test first tho so u dont go and waste money on something that wasnt broken..good luck
fast_s14
Car: 94 300zx
Im not gonna say that your starter is broke, but mine made the same noise when the aluminum housing was cracked at the end of the starter. When i would go to crank it the housing would seperate and it would throw the bendix off center. Replaced the starter and the noise was gone. That was my issue and may not be yours, it is worth looking at tho.
N!SMO SILVIA
Car: 95 240sx
Andyb2637 wrote:Oh yea did you check the teeth on your fliy wheel? Your flywheel could be warped alil? it could also been your starter you could take it to autozone to let them test it(its free) so yea id do the starter test first tho so u dont go and waste money on something that wasnt broken..good luck
fast_s14 wrote:Im not gonna say that your starter is broke, but mine made the same noise when the aluminum housing was cracked at the end of the starter. When i would go to crank it the housing would seperate and it would throw the bendix off center. Replaced the starter and the noise was gone. That was my issue and may not be yours, it is worth looking at tho.
Ah i see. Ok i gotta check the flywheel then and for sure I'll take the starter to autozone and see if they can find a problem with it. Thanks for all the help guys. Really appreciate it.
wawazat8402
Car: 89 Sil80- RB25DET
if you can find a shop the rebuilds starters and alternators, i would go with them instead of autozone or parts stores of the like. ive had too many bad alternators they thought were fine which led to unnecessary money being spent only to have a real shop tell me they were bad.
N!SMO SILVIA
Car: 95 240sx
wawazat8402 wrote:if you can find a shop the rebuilds starters and alternators, i would go with them instead of autozone or parts stores of the like. ive had too many bad alternators they thought were fine which led to unnecessary money being spent only to have a real shop tell me they were bad.
Thats makes sense since they specialize in those parts. I know what you mean about the unnecessary money spending. Happened to me recently LOL
N!SMO SILVIA
Car: 95 240sx
Could this problem also be caused by bad spark plugs?
S13 240SX
Car: 93 Mazda Miata
the video is still private..
N!SMO SILVIA
Car: 95 240sx
Ok sorry again about that. It probably reset or something. Its public now.
S13 240SX
Car: 93 Mazda Miata
it sounds like a timing belt at 7 to 8 seconds into the video.
N!SMO SILVIA
Car: 95 240sx
Hmm...
I'll keep on searching other possibilities and try to pin point where the sound is coming from. Really want to know whats causing this and replace. Any other ideas? Thanks for all the help guys!
240z4u
Car: '95 Nissan 240SX
Did you torque your flywheel correctly? Sounds like an improper gear mesh.
It sounds like the starter could be the problem like they said, the bendix may not be disengaging fast enough.
Evan
S13 240SX
Car: 93 Mazda Miata
it sounds nothing like a damn loose flywheel bolts..
i have had that happen to me beforre and they are a lot louder, plus they dont sound like rubber either.
This is why it could be a timing belt or something into 7 or 8 seconds in the videol.
also my rb20det my timing belt made that noise when i first replaced it didn't have it tension right at first.
The best thing to do is to take another video with the hood open and the camera on the engine
N!SMO SILVIA
Car: 95 240sx
I will record another video tomorrow morning. Hopefully its the timing belt. I'll probably buy one if thats the case and just replace. Standby guys.
