Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Mon Mar 05, 2007 8:09 am
OK, well the 2nd guy who wired my car came over. Cleaned up the harness and routed it nicely for me. He also RE-wired the MAF.The person who wired it for my originally wired it incorrectly.
It started with the MAF for the first time but then died out.
So I'm going to try the RB25 MAF, next week.Will the RB25 MAF need to be re-wired or will the ECU have to be modified???
Also, I've now found out that I have no Tach signal coming from the ECU. I've tested the #7 pin on the ecu and no voltage comes out, and I've also hooked up a wired under the hood. ( the wire that's in that little tube with the cap on it)
I belive my tach works (aftermarket DEFI), I've used it before and when I touch the signal wire for a QUICK sec to the + side of the bat the needle jumped.
Anyone have any ideas on that??
