I just got my RB swapped into my 280Z and I'm having issues with fuel pressure loss once the engine gets hot. I did notice that shortly after the fans for the radiator turn on, pressure slowly starts to drop and eventually hits 0 as the engine bogs out. If I try and start the car again it wont start. Like if no fuel is getting to the motor. Fuel pressure stays at 0. If I let it cool down I can start it back up but once it heats up pressure falls all over again.
After a few times of doing this the battery drains out. Could it be a power issue that's affecting the fuel pump? I have a Bosh 044.
Any ideas on what could be causing this?
The shop that did my work is about 250 miles away so I am trying to see if I can figure the issue out before towing the car up there.
Any help is appreciated!
