Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Sat Oct 04, 2008 11:32 pm
Running a bit rich would be my guess.
My RB25 was running like you say yours is, at the time i had, fmic, intake filter, full 3'' exhaust, and a greddy intake manifold, walbro 255 and the stock FPR i put down 225 rwhp at around 12 psi. I re-did the timing and advanced it 5 degrees and took out a 5 percent correction and dropped the boost to about 10 psi and made 272 rwhp at 11.1-3 afr's. Find a way to check your timing, set it, find a way to monitor your EGT's and AFR's via WIDEBAND 02 system ( zietronix, plx, techedge...etc.. ) or AEM uegos gauge.
Just a start.
