He says that the car drives, but doesn't go into boost, and that the plugs he put in are fouled. Also that he can smell a bit of fuel at times. He hasn't installed his wideband so I can't check the AFR's.
When I went to check out the car, the maf was not properly secured to the coupler that it was on, all other connections seemed to be straight. When I disconnected it, the car shut straight off. no limp mode. (Of course, now that I look back,I believe I should've told him to try and start the car when it was disconn. huh?
Now, the car boosted fine when he got it, seems like the problem developed around the time when he tried to install an AFC. The harness colors were not the same as the instructions. Maybe the wrong wire was cut, but he followed the instructions by the pin location. Then decided not to put it in.
I didn't have my multi-meter, or the testing procedures for the rb25 maf on me since I only went for a look, so I couldn't check it. I guess I could go back and try it when I find the info. So, does it sound like a bad maf, or just shoddy wiring?
Speaking of wiring, the harness is a mess. connectors everywhere, and like I mentioned, he said the wire colors didn't match for the AFC instructions. Now I'm not 100% sure if he used the skyline or silvia instructions, as they would be different right? but seeing as it would be those 2 put together it wouldn't be too hard to figure out no?
My second question would be, which replacement harness(es) should I get? This is an S14 Silvia, so should I try to find a complete SR20 harness, or would a 240SX harness be able to work without giving me too much extra headache? The wipers and A/C are not re-wired back in and that WILL have to be solved. It seems the engine part of the harness is fine, it's just where the wires are spliced (near the connector by the ECU) that has that buttload of connectors on the wires.
I guess it's here where I got a lil confused. It should be a complete RB25 harness from engine to ECU right? and then connected to the S14 body harness? or is there a bit more than that?
Cliffnotes: RB25DET will drive, won't boost. Potential maf problem? Which harness would be best to use in the S14(silvia, not 240sx) for this project as a replacement?
Anyone need more info just let me know and I'll find out for you. I'm quite determined to get this car, and I would like to have the shortest downtime for this particular problem so I can move onto more important things with it.
