ok iv been searching but there isnt alot of info on how to put a rb25 into a hardbody. so after doing some research i think i have found an almost bolt in friendly way. what you you guys think??? possible: Is there engine bay room Do i need fire wall modification
the ka24e in the truck and the ka24e and ka24de use the same engine brackets. so by using a 240sx rb swap kit designed to mount to stock subframe the motor should bolt in...
http://cgi.ebay.com/ebaymotors...aed1aor are those mounts to bolt to the frame and u use the stock rb25 engine brackets???
also the hardbody came with the vg30e, which uses the same transmission(different bellhousing) as the rb25, so if i buy the vg transmission crossmember it would be close to being bolt in, or very little modifications.
http://www.courtesyparts.com/h....html a diagram of the crossmember.
the transmission crossmember is part #11340m
the transmission mount is part number #11320same as the 300zx transmission mount part number
http://www.courtesyparts.com/3....html
another question, is the rear of the 300zx transmission and the rb transmission have the same mounting points???and what is the distance between the mounting points between the engine brackets and transmission mount for the vg/transmission combo and the ka/transmission combo. ill go take measurements tomorrow and post them up.
let me know what you think
