RB25 into S13 swap d member question!!!
Starclassicbb
Car: 89 S13 coupe/no motor
Hey!! I gotta a question! i'm having plans to do make an RB25 swap in my s13 i don't know about a lot about this swap but everytime I go to any forum they always talk about the R33 crossmember , sooo this is my question!!! do you have to get the r33 crossmember in order to do the rb25 in the S13?
Modified by Starclassicbb at 6:01 AM 10/8/2009
ka24eracer
Car: 180sx...
No you dont there is alot of other alternatives , search before being flammed ...
Starclassicbb
Oh ok.. Yea I know I need to get the motor mounts, transmission mounts & driveshaft
ka24eracer
Car: 180sx...
exactly ! There is also the normal parts , like fuel pump , thicker rad ...!
kwin507
Car: s13 coupe
i just recently finished my rb25 into my s13 coupehere is all the things i bought-rb25det series II 2,500 includes full motor,trans,uncut harness,ecu,maf w/filter, and sensors (JapaneseEngineImports) -jgy motor mounts (JGY)-driveshaft shop driveshaft (Phase2motortrend)- walboro 255lph (Phase2motortrend)-fuel pump cover gasket (Phase2motortrend)-29x11x3 intercooler (CXracing)-2.5 universal piping (CXracing)-t bolt clamps (CX racing)-silicon hoses (CX racing)-2.5 elbow (CXracing)-oem water pump (FRsport)-oem timing belt (FRsport)-thermostat nismo (FRsport)-aem dry flow air filter (FRsport)-samco radiator hoses (FRsport)-spec stage three clutch kit (FRsport)-nissan 95' quest alternator (Advance Auto Parts)-ka24de temp switch/sender (Advance Auto Parts) -s14 throttle cable or custom bracket (Lowes)-circuit sport coolant resevoir (FRsport)-ISIS 3 inch dual core radiator (RAWBrokege)-2 pusher fans from advance one big and one small (Advance Auto Parts)-new dayco belts ps and alt/wp (Advance Auto Parts)-300zx speed sensor 95' i believe the longer one. (Advance Auto Parts)-BKR7E NGK plugs .8 gap ( Advance Auto Parts)-vlsd -new vaccum and fuel lines (Advance Auto Parts)-300zx fuel filter (Advance Auto Parts)-ka oil filter (Advance Auto Parts)-then oil,gear oil,plenty of anti-freeze
i think thats about everything i got mine runs fairly well besides the draining of my voltage somewhere
Modified by kwin507 at 7:23 PM 10/11/2009
kwin507
Car: s13 coupe
o and stock crossmember
flatrate
Car: S14 kouki
kwin507 wrote:i just recently finished my rb25 into my s13 coupehere is all the things i bought-rb25det series II 2,500 includes full motor,trans,uncut harness,ecu,maf w/filter, and sensors (JapaneseEngineImports) -jgy motor mounts (JGY)-driveshaft shop driveshaft (Phase2motortrend)- walboro 255lph (Phase2motortrend)-fuel pump cover gasket (Phase2motortrend)-29x11x3 intercooler (CXracing)-2.5 universal piping (CXracing)-t bolt clamps (CX racing)-silicon hoses (CX racing)-2.5 elbow (CXracing)-oem water pump (FRsport)-oem timing belt (FRsport)-thermostat nismo (FRsport)-aem dry flow air filter (FRsport)-samco radiator hoses (FRsport)-spec stage three clutch kit (FRsport)-nissan 95' quest alternator (Advance Auto Parts)-ka24de temp switch/sender (Advance Auto Parts) -s14 throttle cable or custom bracket (Lowes)-circuit sport coolant resevoir (FRsport)-ISIS 3 inch dual core radiator (RAWBrokege)-2 pusher fans from advance one big and one small (Advance Auto Parts)-new dayco belts ps and alt/wp (Advance Auto Parts)-300zx speed sensor 95' i believe the longer one. (Advance Auto Parts)-BKR7E NGK plugs .8 gap ( Advance Auto Parts)-vlsd -new vaccum and fuel lines (Advance Auto Parts)-300zx fuel filter (Advance Auto Parts)-ka oil filter (Advance Auto Parts)-then oil,gear oil,plenty of anti-freeze
I hope its just the picture... but did you turbo charge the crankcase...lol
looks like the crankcase vent on the valve cover is going into the charge pipe
Starclassicbb
kwin507 that's a nice swap!! But why does the motor looks tilted? Is that normal? & what's the difference between the series I & series II?
kwin507
Car: s13 coupe
thanks it would look a lot better with a greddy style mani. but yes all of the motors are slanted check the ka24de in the car when you have the chance its slanted also. Really looking at the series I and II the only thing i saw different was the elimination of the ignitor and the II would be a newer motor with less miles
kwin507
Car: s13 coupe
lol naw its all just stock and normal
