RB25 intake cam gear NVCS module gasket?
DETurbine
Car: Nissan S13 RB25
Searched around and couldn't find anything on it. Trying to fine the o-ring that goes around on the inside plate cover for the NVCS module intake cam gear solenoid. Mine is starting to leak and wondering if there is any interchangeable part here in the states before I purchase one over seas.
***This is the plate that sits on the front of the intake cam gear. There are (4) 7-8mm bolts that hold it onto the module/gear.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I would measure it up and try to find a match on McMaster-Carr. It will probably cost $10 and you'll get 20 of them, but it may end up being cheaper than an "OEM" one.
DETurbine
Darius wrote:I would measure it up and try to find a match on McMaster-Carr. It will probably cost $10 and you'll get 20 of them, but it may end up being cheaper than an "OEM" one.
Yeah I was thinking about doing that. I will have to double check with both OEM and that site. Luckily my friend in Japan can get me OEM parts for pretty cheap.
eh?
DETurbine
