you're supposed to use an R33 GTS-T crossmember with the syko kit. mckinney uses the stock s13 crossmember.240z4u wrote:Uh, correct me if I am wrong but aren't you supposed to use the syko kit with a stock crossmember?
i don't think i did anything wrong. i took the crossmember (while out of the car) and tried to connect it, with the syko mounts, to the rb and it just wasn't quite right. i'm gonna take some pictures of the brackets on the engine and post them cuz something isn't right and i'm not sure what.s14_sport wrote:
theres a picture of the one you should be using and they look the same to me...
you might be doing something wrong...
yeah i still haven't had a chance to go back out to my friends shop and take pictures of the brackets. i'm hoping i'll be able to go out there in the next day or 2. but i'm pretty positive now that the brackets are wrong because i just found pics of the correct brackets, and the ones that are on my motor are definitely not the same. thanks for confirming the crossmember is the R33 GTS-T. i had been questioning if that was the correct one.Coolwhip wrote:to confirm, your are using the right crossmember and that of the first pic is in fact a R33 GTST one.
Perhaps the brackets on the motor are conversion mount brackets that were never removed when you got it. Or where from another car.
The Syko's should work fine with factory engine mount brackets and that crossmember. And as you assumed, Pics would do everyone good in helping you out on this.
haha hey Ricky! I'm gonna go ahead and order those brackets cuz i'm positive the ones on my motor are not the right ones from seeing the brackets you have.Coolwhip wrote:Hey Tim, its me Ricky. Been talking to you via email.
