StricNyne »
https://forums.nicoclub.com/stricnyne-u10935.html
Tue Jul 07, 2009 7:43 pm
well i got it running but it dosent want to idle and turns off, my afrs are around 10~11 ish and an odd problem i have is that i am running a z32 maf but when i select z32 maf from the afm section on my power fc it runs worse it perfers to see r33 any suggestions, also when i did my fuel pump, when i turn key to acc it stays on while there instead of normally just priming is this an issue i know it did not do this orgignally, i just wired the relay to take constant power when turned to acc, i did not use the oem relay because i was not sure which relay to use, the ecm one or the one from the passenger foot
