madmaxfreelance »
https://forums.nicoclub.com/madmaxfreelance-u54147.html
Wed Nov 23, 2011 10:10 am
Hiya everyone, I'm getting ready to start cobbling together some parts for a swap into my S13 and wanted to run my game plan by ya to get some feedback. My final goal is 500 whp, short term goal is "get a rb in my car."
So far, my understanding is that the RB20 transmission will bolt up fine to the RB25 and work with the S13 driveshaft and line up the shifter correctly without hacking up the trans tunnel.
I also know that the RB20 transmission is weaker than the RB25 transmission. How much weaker I can't seem to tell exactly. Will it hold 500 whp? Where's the line on it?
So here's my current game plan:
Engine: Buy RB25DET series 2 motorset with no trans. Replace all gaskets, valve seals, belts, and timing pulleys before installation. Fix oil pump problem if necessary? Does that apply to s2 motors?
Mounting: zerolift mounts and some decent aftermarket motormounts (nismo or something)
Drivetrain: RB20 transmission with stock S13 driveshaft and the Z32 LSD that's already in my car.
Wiring: seems to be a wealth of resources for wiring it up online. Not scared :p
Manifolds/Turbo/Injectors: I'm a complete turbo noob, so my plan is to keep it stock till I get everything else installed and working and then go for some upgrades down the road when I have a better understanding of forced induction tuning.
Downpipe: Get one of those ebay conversion downpipes. I mean it's a piece of pipe, the Chinese can handle that I think. Dunno if this will work with the zerolift mounts and stock cat location though.
Intercooler: silvia SMIC. I loathe cutting, grinding and welding so looks like FMIC is out.
I've already got dual electric fans and a walbro fuel pump in my car.
Any input or corrections are welcome, specifically I'm trying to make sure that I am correct in thinking that the zerolift mounts + RB20 trans + stock driveshaft will play nice together.
Thanks
