RB25 Idles High and doesn't like to start
d356bud
Car: 1990 240sx w/ RB25DET
Well the car ran great mid winter, but now it doesn't like to start. Also it idles around 1500-1700 RPMs. I haven't changed anything since the last time I started it back in February. I didn't get a chance to reattach the wideband, but I checked the ecu and it isn't throwing any codes.
Specs:
built RB25DET
HX35
740cc injectors
rb20 ecu with a eprom chip from Carl
Stock ignition
z32 maf
Anyone have an idea?
Ramius83
Car: 1995 240sx SE
For craps and giggles, when it is not wanting to start, try disconnecting the mass air flow and then starting it. If it starts right up immediately after unplugging it, that is your culprit. That is an easy 1 minute thing to do first. Theck check back........
mixeds14
Car: 240
u might wanna check ur fpr, when it goes bad, it will crank for a bit b/f it starts up..
Cjmartz2k
Car: Hunting for a '89 GTR now
Sounds like a vacuum leak to me. Some random hose might have cracked over the winter.
d356bud
I'll have to give these ideas a try this weekend
d356bud
Well I gave these ideas a shot. The MAF idea didn't work, it just made the car run super rich. I also check my fuel pressure and its fine. Although I did hear a strange sound coming from the gas tank. It sounded like a groaning sound from the fuel pump. So thats a problem for the near future that I'll have to address. I checked my hoses for leaks and I couldn't find any. The PVC valve might be the culprit. If it isn't then I'm think maybe the AAC or IAC?
