l0nestar »
https://forums.nicoclub.com/l0nestar-u38221.html
Mon Mar 19, 2007 6:42 pm
Alright,
I have finally began re-assembling my RB and got stuck when attempting to install the timing belt. Of the 50+ labeled bags, I seem to have mis-placed the bolt for the idler. I used a tap + machinist rule to measure what I think the bolt should be and I got M9 x 1.25 x 80mm. Can anyone confirm this or give a replacement part number? Would a Z31 replacement bolt work? Are they the same since the tensioner is? I tried going through FAST and could not find the idler listed and also went through the FSM and it just gave the torque specifications.
I tried a few parts suppliers local (Ace, Fastenal) and even McMaster-Carr. Nobody carries M9 (9mm) bolts! If I cannot find a suitable replacement, I am going to tap it out to M10 ( along with the bearing itself) and go that direction, but I would rather not, if I didn't have to. (of course!) What also concerns me is that I cannot find the original idler OR the bolt.
Thanks in advance,l0nestar.
