lazyeyes13 wrote:No I'm pretty sure my bov is recirculated...theres a hose coming off of it running back to the intake manifold (greedy)
When I rev the engine up and it comes back down it has trouble catching itself, I have to feather the gas to keep it running... and whenever it does this is runs really rich (black smoke coming from exhaust)
Im going to double check timing and adjust the idle and hopefully that'll do it!!
Any other suggestions guys??? Any help is greatly appreciated!!!
Check the IACV underneath the intake manifold. The screw on it should be screwed all the way in and backed out about 1/2 turn. Also, it sounds like the system is not air tight so you should do a pressure test on your piping to make sure there isn't a vacuum/boost leak.
There should not be a hose running from the BOV to the intake manifold unless you are talking about the boost reference line. The BOV should recirculate back to the turbo intake pipe downstream of the MAF sensor.
