I run an AutoLight racing plug. There like 2$ a piece. Ill have to see what the part # is. its been a while.
Also I have not messed with Nistune stuff either. I personally LOVE the Megasquirt and wastedspark LS2 coil setup.
Megasquirt Gives you full capabability of everything IMAGINABLE on a car.
So far I have had alot of sucess with the megasquirt.
You can call DIYAUTOTUNE and give them your setup and they will build you an ECU for around 530$
They send you a wiring harness thats labeled and easy to install. You may have to change a Couple of wires in the plug for the coil setup and if you do a launch control setup ETC.
If you really wanna learn to tune your car your self. Megasquirt is the way to go IMO!
You can check out my setup here in this Build thread!
zer...age=1
