rb25 high oil pressure?
lazyeyes13
Car: 1991 s13 hatch rb25det
1989 s13 hatch
2004 g35 coupe
Hello,
I have a s1 rb25 in my s13 and my oil pressure seems a bit high... After warmed up it reads just below 40psi at idle and then goes past 80psi when revved up
40psi at idle seems a bit high right? What could cause this? Im running 10w30 mobil 1 full synthetic oil
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
How long after the car is warmed up? It takes a while for the oil to get up to operating temp, longer than the coolant.
lazyeyes13
1989 s13 hatch
2004 g35 coupe
Like after driving it around for a good 30 mins, the oil pressure at idle always reads just below 40psi, I would think driving it that long would get it warmed up
Darius
Oil pressure for the RB20, RB25DE, and RB25DET are specified as follows:
Idle (650 rpm) - 14.5 psi
2000 rpm - 46.9 psi
6000 rpm - 79.6 psi
Oil pressure for the RB26 is specified as follows:
Idle (650 rpm) - 21.8 psi
2000 rpm - 42.7 psi
6000 rpm - 65.4 psi
When you are seeing 40 psi of oil pressure, what is the engine rpm?
Have you changed the oil pump since you have had the car or is it still the stock unit?
lazyeyes13
1989 s13 hatch
2004 g35 coupe
Oh I idle around 1000rpms that's probably it
And the oil pump is still stock
