DanDrath »
https://forums.nicoclub.com/dandrath-u133577.html
Tue Jun 07, 2011 9:23 pm
ok so my friend has an rb swapped s13 he bought swapped, previous owner did the swap and rebuilt the motor, he had a bad pcv valve and replaced that and a bunch of boost leaks all fixed, his car brakes up at higher rpms. we did a boost leak test and got air out of the dip stick again, then we compression tested the car and got 170 in every cylinder, so i am stumped what the problem is/ Please help guys.
thanks~
~Dan
