Well I had some issues last year with a freeze plug that blew out. Had it towed home. Then found a rubber expanding replacement (bad idea) which blew out...or fell out a couple months later. And I had to drive it a little ways with low coolent (block and pistons are fine) Wasnt the best idea i know but I was kinda stuck on what to do unfortunatly.rb25drag wrote:If there knowledgeable at all they should be able to fix it. But if they don't wanna mess with it they might tell you they can't. But you should call and ask them. And have them put a mic on it to check the cam caps and make sure you don't have a cap causing it not to spin. It would take ALOT of heat to worpe that head that bad. Im talking over 300 degrees for a long period of time.
As far as me and a few buddies can tell the bottom end is fine...but it is coming apart anyway to inspect closer. And no I didnt ask for a number, he just told me it was in pretty bad shape and to do that check when I got home.Shocker wrote:you sure your bottom end is cool? thats a good deal of overheating for it to warp the head... did you ask them how many .xxx it was off?
I had done that and I saw only one and they guy wanted 500 for it.disrupt wrote:ebay . . . .
search "rb25det"
Glad to see you took the pan off and looked. You will be happy with the ACL bearings. I am with mine so far.gomer23 wrote:Well I did take the oil pan off yesterday and inspected the bearings. One had a hint of blue in it, so I am replacing them all (i had some ACL ones anyway) So who knows.
So if anyone has a suggestion on a place to try for a head or anyone that has one let me know. Thanks.
Yea I am glad I looked too. And I have the money, just didnt want to spend it if I didnt have to. But I got that one off ebay for 400 shipped so it wasnt terrible I guess. Oh well just need to get my oil pump, and timing belt stuff ordered and I get this beast put back together.rb25drag wrote:
Another head is going to be pricey. Thats why I suggested possibly fixing the one you have, if you don't have the cash.
