Coolwhip »
https://forums.nicoclub.com/coolwhip-u13264.html
Wed Feb 25, 2009 7:21 am
As mentioned your factory manifold can be used and modified to run an external wastegate. Common area for this is above the turbine flange between the runners.
Boost controller, will be needed if running any boost pressure outside the rated spring pressure in which you would've ordered with your wastegate. (ie: if you have a 12psi spring in your wastegate, and you plan only to run 12psi, then you'll be to go) however, it can not hurt to have it controllered or monitored with one.
Wastegate size, 38mm is the common. Fits well in the space given.
Oil restrictor size .035" and to be on the oil feed line going into the turbo.
Get the usual downpipe, dump/wastegate tube, oil and coolant lines, hot pipe, and intake pipe situated and you are good to go in fitting it.
The above is just one of a few routes you may take.
GL
