nope, ive got a new rb25 pfc to be used on my rb20 when i get her back together.......StricNyne wrote:i hope u mean used
Carl H wrote:nope, ive got a new rb25 pfc to be used on my rb20 when i get her back together.......
tru, but the pfc can handle the power no doubt but it can be tricky if you need more than a 20x20 map resolution.even when upgrading to a q45 maf, while it can cope with increaced airflow your tuning accuracy and resolution drops.if the pfc doesnt work out for me i may go to aem, but ive much faith that i can hit 500whp on a pfc.eh? wrote:Had a PFC now have a Aem Ems. The aem is hands down more capable, feature rich and easier to tune. However if you looking for sub 500whp the PFC may be a better choice cost wise.. I believe with the RB25 PFC you are limited to the resolution of the single z32 MAF while the ems is in all sense unlimited.
gm two tower coils yes on the cam angle sensor and yes on the crank trigger.... ATI built me a custom ballencer with a trigger built in to it . it also has the drive for the external oil pump on the end .....FrostyRB wrote:Nate what type of coils are you using with the FAST system & are you using the factory cam sensor, or are you using an aftermarket crank sensor. Also can you dial in your fuel in less then 500rpm incraments.
