autocrossing »
https://forums.nicoclub.com/autocrossing-u73624.html
Mon Jun 16, 2008 6:17 am
Well damn, can't remember where this flywheel came from then. Must be off a truck KA, it's a 6 bolt 240mm. Anyways, the reason I'm asking is because I've been having clutch engagement issues with my RB26 w/ RB25 trans. I originally had a OS triple disc for the engine, when that went bad I decided to go with a less aggressive clutch which meant I needed to find a flywheel. That's when I picked up the flywheel I'm using now. I'm leaning towards the problem being either the throwout bearing or TOB sleeve, but I figured I'd check the flywheel as well.It's kind of an f'd up combination, RB26 with 25 trans, KA truck flywheel, Z33 pressure plate & TOB, NA Z32 disc...
Thanks for the help, Marshall
