oneslow240se wrote: Ima need this info aswell... not to jack your thread since its also flywheel related does anyone knoe if the N/A 300z and rb flywheel are the same spec? i need to get mine resurface and the place needs to knoe what car its from (i doubt R33 Skyline will be in their manual)
searched and found this...
zerothread?id=61019
Modified by oneslow240se at 1:12 PM 10/16/2007
They are the same spec, however they use different bolt patterns on teh crank. The NA Z is an 8 bolt crank, and the RB being 6 bolt......
You can install an NA Z32 clutch kit on an RB25/26 Flywheel however. I just did this last week....
FWIW on the flywheel torque, I always just throw some red loc-tite on it, start the bolt by hand, and hit it with the impact. I've probably done 20 nissan clutch jobs and not a single one has had any issue
