wakotow »
https://forums.nicoclub.com/wakotow-u117588.html
Fri Sep 11, 2009 1:22 pm
I have a safc that'll log air flow, or at least percentage of air flow, the highest I've seen is like 52%, I have still to learn how to view the whole log, just peak, I'll look it up. It's not recording any knock, now I know the sensor is putting out some voltage so it's not completely dead, but it may be completely malfunctioning, I'll test it by tapping the block with a screwdriver later tonight, but then my question is, if the knock sensor is dead and doesn't respond to knock, then how would the ecu know it was knocking?
The holset wastegate is pretty stinking small (less than an inch in diameter) and the way the lever works is it stops after it is just cracked open, so it probably only gets about 30 degrees of actuation, so I doubt I'll be able to fix my creep without at least major porting of the hole and cutting back the part that it stops against...Otherwise I'll be shelling out a couple hundred to get a wastegate.
Oh if only there were dyno's here, the only one I know of is at the Porche dealership, and I'm not even positive you can pay to use it. My only hope is that the two shops in town that have just opened within the last 18 months or so get theirs up and running, apparentally they are in the process of installing/calibrating/struggling in the economy, so ya.
I may have found the problem, or at least something that wasn't helping. My fuel pressure at idle was 44psi, and without vacuum at 53or so psi, I must have thought I was looking at 43 instead of 53 when I got my afpr, now it's back to stock and I'll be driving it later this afternoon to see how it acts.
