rb25 engine shut off!
Z-tune!
Car: RB25 S13
Hey guys, I recently replaced my turbo, turbo lines, exhaust gasket, clutch, flywheel and injectors. Added a catch can and made an intake pipe. the problem im having right now is engine shut off or stall when not in gear and when i let off the throttle. i know i have a problem with the pcv valve/grommet leaking air. I also experience possible compressor stall/surge. could this air leak cause the blow off valve to not work properly? it's an HKS ssqv blow off valve. and i know 100% that i have the catch can hooked up correctly. between the exhaust rocker cover and intake pipe(preturbo).
any insight would be great, if i missed anything let me know. thanks in advance
Z-tune!
Car: RB25 S13
any help on this?
could it be the maf getting an inaccurate reading from the larger turbo? pcv valve? bov recirculation problem? improper fuel pressure? someone help me! D:
