Ok I do have that Yellow Blue wire in the spot you described. Thanks.Darius wrote:That is weird that you don't have a metal piece in the #7 location. Not to belittle you or anything, but are you sure you're reading the wiring diagram for the harness plug correctly (i.e. not backwards)? The tach wire is Y/L (yellow/blue) the fourth pin to the right of the harness bolt on the top row.
The yellow/"lavender" is actually the Y/PU (yellow/purple) "AG04" wire for the check signal on diagnostics.
