Rb25 ecu loosing power
DropTopRB
Car: 1993 240sx convertable, RHD, chargespeed s15 front end and wide body full kit, powerd by rb25det
Hey guys, ive got a rb25 into s13 was running a year and a half ago, went to start it 6 months ago and wouldnt start. Found eccs wasnt getting power, jumped the relays and the car started. Now when i jump the relays i get power to the ecu, but when i crank the car over the ecu looses power, light goes out on the ecu and i get a really week or no injector pulse at all. Any ideas????Thanks!
Kevin.A
Car: Nissan 300zx RB20 swapped
How olds your battery?Does power come right back after you let go of the key?
DropTopRB
battery is kinda old, ive had a charger on it the whole time. Its just the ecu loosing the power the rest of the vehicle still has it. Once i stop cranking the engine the light on the ecu does come back on a few seconds after.
robbie2883
Car: 1998 RB25 Kouki
sounds like somehow either when you tapped your original power or bypassed everything you tapped into a accessory source instead of ignition source. ignition keeps power through start and accessory only has power when the key is in the on position. goes to zero when starting and then back to 12 volts.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
you jumped it wrong! you have it set up to acc pwr instead of 12vdc power. check your jumpers again
robbie2883
USMCgetsome wrote:you jumped it wrong! you have it set up to acc pwr instead of 12vdc power. check your jumpers again
you mean ignition power right?
DropTopRB
So i cant jump it from battery power, and run a switch to it???
robbie2883
just run it to an ignition wire off the fuse box or even better directly from the ignition harness. i would put a fuse in the wire though
