Cjmartz2k »
https://forums.nicoclub.com/cjmartz2k-u65761.html
Mon May 18, 2009 6:51 pm
Sounds like you've got a LOT of research to do.
-I wasn't saying I thought it was your headgasket. I was saying white smoke is a sign of headgasket/coolant getting burnt, and if your friend said white smoke means it isn't the heasgasket, don't ever listen to him about cars again.-You might have milky oil or nasty coolant from a blown headgasket, but not always. Compression check is the way to see. -How's your oil level?-You could be getting coolant from a blown turbo, along with burnt oil. Depending on how the exhaust wheel s*** itself, it could have taken out the seals with it-Whether or not a turbo is ball bearing has very little to do with it's performance, and a lot more to do with it being expensive. There are non-ball bearing turbo's out there that out perform BB turbos due to better wheel design, twin scroll, variable ex housing a/r's, etc. Would I rather have my Holset turbo have a BB center cartraidge? Yep (if I didn't care about ever having to rebuild it).
Jack the car up, disconnect the front of the cat, and look for random parts that don't look like they are supposed to be there, and no, I wouldn't drive it until then.
