RB25 crank pulley bolt socket size?
chixwithtrix
Car: Black '91 240sx drift car
What size is the RB25 crank pulley bolt? In a writeup I saw that is was 23mm, but that is too small, I have not found any other information and I need to change the timing belt. Is it a 27mm?
imotion s14
Car: 1997 240SX
chixwithtrix wrote:What size is the RB25 crank pulley bolt? In a writeup I saw that is was 23mm, but that is too small, I have not found any other information and I need to change the timing belt. Is it a 27mm?
27mm like pretty much all harmonic balancer bolts on Nissans.
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
I can confirm this later on when I'm home from work.
chixwithtrix
excellent, I put a dial caliper on it and came up with the 27mm. I've been running around all day for other parts and I just wanted to verify this before I made another trip
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
zerothread?id=244427
Alittle confirmation info there
