your thinking of the sensor for the gauge cluster. Thats a single wire.FriedEGs wrote:hmmm.. I think I used my KA sensor when I did my swap.. I thought everyone did that?
Sh*t...I switched out the wrong one.. I used the KA 2 wire (red) sensor.. What's the difference between the two?Shocker wrote:
Not sure if that coolant temp sensor works, the 2 wire one.. but If you wired it up and its working then leave it.FriedEGs wrote:
I used the RB single wire for teh dash gauge, and it seems to be working properly.. Is this the same wire I should use to hook up an aftermarket gauge?
Did you wire in the connector for the KA for the coolant temp? or did you use the RB's connector? Depending on your year... Im pretty sure they are different.FriedEGs wrote:I'm assuming the KA 2 wire is working okay.. I'm having a problem with boost issues as you prolly saw in another thread.. but, i don't think there is any link to that problem with this ka 2 wire coolant sensor...
As far as the single wire rb sensor is concerned.. the temp gauge on my KA cluster is reading a steady temp just below the half mark. I wonder if my car is running hotter than indicated... It sure is hot under the hood, but, I'm not getting any boiling from teh coolant.
If you have the KA gauge just make sure you have the KA temp sensor installed. Otherwise it will read incorrectly.
