How do you know you're car doesn't overheat? what gauge are you using?
The coolant bleeder screw is located right next to the intake manifold. Its the thing sticking out with a 10 mm screw on it. It also has lines going under the manifold, and to the throttle body.
You can also bleed from the radiator cap itself.
Run the car to normal op, run the heat full blast on high, rev to 3k for 5 minutes.
Let sit 5 minutes.
Take rad cap off , wait 5 minutes
repeat till the water in the radiator doesn't move after taking off the cap.
backsidethree wrote:Where exactly is the coolant bleeder screw on the rb25? When I drive my car to and from college, (A 2 hr drive) It runs fine and does not over heat, but within 10 seconds after I turn off the car, the coolant boils and pours out of my resovior.
