Chaos the Xile »
https://forums.nicoclub.com/chaos-the-xile-u37171.html
Mon Dec 04, 2006 5:45 am
Yes and when we did a comp test, it was dead nuts cold outside, just pulled the car off of the tow truck and into the garage and began ripping it apart for the test. But since the timing issue I can't keep it running stable for long period it'll keep dying out. So I guess once the inital problem is solved then I can move from there... I don't think the compression is bad when I fisrt got the motor running it was like 155, 160's and was kicking like a pissed off stallion.
