Postby
SlowKoop »
https://forums.nicoclub.com/slowkoop-u123505.htmlMon Mar 28, 2011 1:48 pm
Once again I need nicos help. My troubles started one day when I was driving home and I noticed on the power fc that the water temp sender was reading all dashes. Well when I got home I looked at the plug to make sure it was connected and my after market gauge read normal temps so I chalked it up to bad sensor.went to start my car it just turned over and over no fire. After about 10 minutes of cracking and pumping the throttle it will crank and run fine. Well I have changed the sensor with one from napa. Still all dashes and no start right away? Could it be ground to water temp plug? I changed the 2 wire plug to the ecu by the way as my dash gauge is reading correct.
Postby
SlowKoop »
https://forums.nicoclub.com/slowkoop-u123505.htmlTue Mar 29, 2011 3:54 pm
Does anyone know what the correct voltage for the water temp sensor is supposed to be on the power fc, and what does it mean when is reading at like 6.34v?
