Whenever I check the 1 degree and 120 degree signal on the cas I'm getting good results.
I'm not quite sure how to test in the step that says to check voltage between 2, 3, and ground.
I also jumped wires from the positive , ground, and signal from the computer straight to the coilpacks and there is still no spark. I'm still getting low voltage to the signal wire. I'm told that it needs to be between 1 and 5 volts. But I thought that voltage would be for a series 1 checking the wire after the ignitor.
The coilpacks are also brand new oem and they worked before. Does anyone know the way to test series 2 coilpacks? I believe they only show how to test series one in the fsm.
