RB25: Cam gears, clutch, and exhaust manifold of your choice?
exodus5547097
which cam gears, clutches, and an exhaust manifold do you guys use or recommend for RB25 application? I just want the best quality rather than going cheap and then go buy another similar one.
Modified by exodus5547097 at 7:29 AM 2/1/2009
nismo8117
Car: 93 SilLine
well i am guessing you have a rb25det but as far as cam gears go....you would only be able to use the exhaust side cam gear unless you plan on taking off the vtc for the intake side. As for your manifold it all depends on what kind of setup you are using and how much money you plan on spending. I am using a lovefab top mount manifold. Lastly, your clutch setup also depends on what kind of power/torque you are making and again how much money you want to spend. I am using a os giken twin plate which in my opinion is way to much clutch for a stock setup. Well if anyone has anything else they can through in or correct me on ....
BuH
Car: S13
im using a nismo clutch and a stock intake manifold. mainly stock set up great clutch for mainly stock.
BoostFab
Car: S13cp, S13fb, S14z
exodus5547097 wrote:which cam gears, clutches, and an exhaust manifold do you guys use or recommend for RB25 application? I just want the best quality rather than going cheap and then go buy another similar one.Modified by exodus5547097 at 7:29 AM 2/1/2009
1) cam gears: HKS or Greddy2) clutch: Exedy, ACT, SPEC3) exhaust manifold: BoostFab custom manifold.... (or stock cast manifold for small turbo )
Cjmartz2k
Car: Hunting for a '89 GTR now
I run the HKS gears, but don't like them. I have heard bad things about them, and there is only a couple bolts holding them in position. The tomei units look a lot better IMHO.
As for the clutch, I don't like the super single units. To much clamping pressure/pedal weight and tuff engagment. Didn't somebody have a ACT or cheaper type super single explode on them recently? I'd say a nice twin plate would handle more than what most people with RB25's throw at them.
BoostFab makes pretty good manifolds, along with 6boost and fullrace if you said money was no object.
