RB25 build
Japman
Car: Nissan 200sx RB25
Hi to everyone...I'm new to the forum and as I see you have many technical informations about the RB motors and not only!!! I'm from Greece and my car is a 200sx. When I bought it I take the RB25 engine too...for the swap I bought the syko performance mount kit and some other things!!!I want to ask what else I must take for engine (I have a cometic head gasket 1.5mm,ARP head and rod bolts,and I want to change the oil and water pump to N1) to take without problems almost 500hp!! Thank you and forgive me for my english!!
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Welcome to NICO.
It's pretty easy to make 500hp with a RB25, but as you may have leaned towards, it comes down to a reliability issue.
its all in how much you want to put into your engine's life insurance policy (supporting mods).
Over build your fuel and oil setups, get a killer EMS or tune. All while keeping your engine cool from heat and your golden.
IF taking it into the engine, get some pistons and crank collar. Slight research and you'll find what everyone is complaining about.
Good luck
Japman
yes but i want to keep the oem pistons and rods for now!!!
eh?
If you're not going to replace the pistons, install ARP head studs and that's it for the engine. You're going to break the pistons before you break anything else. Doesn't make sense to install all that and hope the pistons hold up.Leave the oil pumps and such alone. Get a good ECU that can retard and add fuel for knock and EGT's.
Japman
The oem pistons are not suitable for such horsepower? And which ecu believe that is the best for the car??
Coolwhip
Vendor
the ringlands are usually the first to go. And we are talking in a relibility stand point.
There has been numerous of examples of 500hp setups with totally stock internel engines.
So drive it, boost it, break something, rebuild everything :P
Japman
The car in everyday use will not work in full boost!! The 500hp I want it for some times "at night" is so sure that something will be break??
eh?
Japman wrote:The car in everyday use will not work in full boost!! The 500hp I want it for some times "at night" is so sure that something will be break??
With a good tune and fuel you should be okay. Stay off boost in hot and humid weather also keep your rpm below 7500. Have your car tuned on the street/track if possible. I have not had any problems with a 62-1 t3, 19psi, aem ems on a totally stock block RB25. I have overboosted to 24psi @ 5100rpm and the head didn't lift.
Japman
Thank you my friend!!! Can you tell me if you don't mind the cost of the aem ecu,because here the cost is almost 2000euro!! Thank you at all!!!
NPVR6
Car: S14 240SX
I actually just posted about this right above this post. I am going to build with forged pistons, and an apexi power FC.
otightitzjim
Car: S14 kouki baby
Japman wrote:Hi to everyone...I'm new to the forum and as I see you have many technical informations about the RB motors and not only!!! I'm from Greece and my car is a 200sx. When I bought it I take the RB25 engine too...for the swap I bought the syko performance mount kit and some other things!!!I want to ask what else I must take for engine (I have a cometic head gasket 1.5mm,ARP head and rod bolts,and I want to change the oil and water pump to N1) to take without problems almost 500hp!! Thank you and forgive me for my english!!
hey man wasup. im also pretty new to this. i have been on this site forever but i never posted anything. but anyways im also building my series II rb25det. fully done though. keep me posted. i would like to know how your build goes.
Japman
Has anynone here know something about HALTECH ecu!!! Are they good enought????
hachiroku781
Car: 1997 Nissan Maxima GXE
Thessaloniki for the win!!yasou malaka
