This is the best news I've heard in a really long time. I was thinking this but was not sure.gawdzilla wrote:to answer B) Yes, there is a combo that will make the cluster show hot when it really isnt. S14 gauge cluster with the RB sender. are you still using the s14 gauge cluster? did you change the water temp sender out on the RB to a KA one? if not, the s14 gauge cluster with the RB coolant temp sender will read high when it really isn't.
brown color can be normal from surface rust in the block.
That looks interesting. Where can you find that? I've never seen it in normal auto stores. Does that involve reverse flushing with a garden hose? Can that cause issues?eh? wrote:Buy this kit here and the flush fluid. I got a ton of crap out by using it.
The oil/water sludge cakes the walls of your entire cooling system and makes it harder for the heat to transfer to the aluminum.
sounds good. I will def give it a try.eh? wrote:I found it at pepboys. What you do is while the engine is running you flush it with the garden house. Gunk shoots out the tube. I've used it with no issues.
this makes me wonder...i have white face kouki gauges that read properly (not sure which sensor is in mine) but if that is reading properly and has KA temp sensor does that mean my pfc is reading wrong?gawdzilla wrote:this is a known issue with mismatched senders.
it read artificially high on my rb26 which i am 95% sure is the same sender for the gauge cluster as all the other RBs. i have a s14 gauge cluster in mine. i recently switched to the KA sender and everything was fixed. it's so off that when you're at about 180 F the needle is all the way at the H. get an actual gauge if you have doubts.
there are 2 coolant sensors on the motor. the 1 wire sensor is for the gauge cluster only. the 2 wire sensor is for the ecu and is what shows up in the pfc. if the 2 wire sensor is bad your motor will not run right. the 1 wire sensor has no effect on how the motor runs. it is for the needle only. you change out the 1 wire sensor for the gauge cluster to match whatever gauge cluster you are using. the 2 wire sensor should stay RB.robbie2883 wrote:
