FinkenS14 »
https://forums.nicoclub.com/finkens14-u122268.html
Sun Jun 13, 2010 10:39 am
Hey guys I got something to puzzle you with.
For the past week or so my car has bee haing stalling issues when driving. It only happens when driving. What the car does is iIll be driving along normally, and all sudden the car wud cut out for a short second, and then come back on. The car didnt completely shut off because it was in gear, but the best way I can describe it is like letting off the throttle, and then getting back on it, without actually doing so.
Well with that said, I was heading home from a friends house last night when I came up to a light and noticed the car was idling at 10.5 AFRs. When I went to take off from the light the car reved a little bit, then totally shut off. I coasted to a parking lot and restarted the car. Idled fine at 14.7 AFR and I drove for another 20 minutes home.
Then, while on the highway, I went to pass someone, gave it a little bit of gas, and it cuts out again. Car doesnt turn off, but it doesnt respond to throttle input. (I was doing about 70, above 2500rpm).
So I pull over, try restarting the car, and it just starts and dies. Try this several times. Nothing.
So I get outta the car, unplug the MAF, strt the car, idles fine, but at 10.5 AFR's and wont rev past 2500rpm.
So with the car running, I get back outta the car, plug the MAF in, and the car dies. Un plug it again, restart the car, and limp it home.
So then I go over to a friends, and clean the MAF out with electrical parts cleaner. The MAF definately looked cleaner after I did this.
So I go home after the MAF has dryed for about 3 hrs, plug it into the car, car fires right up, but wont rev past 2500.
I still got to check in my SAFC if its sending a voltage at all, and if its showing an airflow percent.
But does this sound like a bad MAF to you guys?
