bmadd2402 »
https://forums.nicoclub.com/bmadd2402-u23099.html
Sat May 24, 2008 7:25 am
I'm a little unclear on what the problem is... It is a small turbo, so goes into boost almost with the throttle, so if you push the throttle, you are gonna get boost. About the "falling on its face," what mods are done, what are you running for timing, who did or guided you in your wiring? all these things will help the process. What have you done to troubleshoot this? My first reccomendation would be to SEARCH, get the FSM and set the timing and idle, along with set TPS, check all sensor voltages, and boost leak test.
