rb25 anytime under boost it spills out tons of oil threw the breather filter
flatblackterror
Car: 91 nissan 240sx
rb25det ran perfectly fine then when the boost got turned to 17psi it starts tossing oil out the breather filter on the valve cover then the boost drops down to 15psi. no oil comes out the exhaust. runs fine as long as it stays off boost but as soon as it hits boost it starts tossing oil out the breather. any suggestions? mods are simple full exhaust, intake manifold, front mount, rad and random things please any input would be appreciated.
Cjmartz2k
Car: Hunting for a '89 GTR now
Stock turbo? How did you not see the 3 million posts about not running a stock RB turbo past 11-13psi? Blown turbo seal man.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Blown Turbo Seals Part II
Neejay
I really hope the stock turbo wasn't upped to 17psi.
What made you think you could do that?
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
the boost controller made him think that. lol.
flatblackterror
a blown turbo seal will make oil pour out of the breather filter?
240z4u
Car: '95 Nissan 240SX
Sounds like your PCV valve could be stuck/leaking?
Evan
flatblackterror
ill look into that but i dont think that the pcv valve is the problem
240z4u
flatblackterror wrote:ill look into that but i dont think that the pcv valve is the problem
Quick to assume for a guy who doesn't know whats wrong.
You better do a leakdown test too.
Evan
Coolwhip
Vendor
ah, I swore i read oil coming out the exhaust.
well, excessive blow by sounds like rings to me.
Compression Test and/or leak down check that motor.
MoogLe
yea,
my buddy's B16 turbo had that same problem a few weeks back, turned out to be broken ring lands on his pistons.
i dont see how a blown turbo seal can make oil come out the valve covers.....blown turbo seals would cause the car to be smoking badly out of the exhaust first and foremost...
that's just my 2 cents
compression test would probably reveal your messed up pistons quite easily
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
There is no way your turbo has anything to do with the PCV system unless like 240z4u said, the PCV is sticking open while the turbo pressurizes the valve covers. That could blow a lot of air thru the system backwards. If the PCV line is not connected or that is not your issue, then it is possibly rings or too much oil in the head.
flatblackterror
turns out the valve seals on the exhaust are shot turbo is good
