i couldn't find any helpful information on that website so i guess my best bet is to do the comparison with both transmissions. after i do the comparison and if they are similiar or even if they aren't i will do a write up on the swap. thanks for the helpHxC_Nismo wrote:since there is not to many people on here that run auto rb trannies your best bet is to get a stock valve body from a z32 and just compare the two and if there the same then i say go for it.
I think d356bud meant that you would probably have better luck posting this question at skylinesaustralia...I haven't seen many, if any people on nico running auto rb's, whereas I've seen more than a few running them on skylinesaustralia. Good luck either way!BUCKY01 wrote:
