716RB »
https://forums.nicoclub.com/716rb-u228792.html
Thu Oct 23, 2014 7:36 pm
Alright, so I have recently finished the wiring needed to run my AEM S2 but I am not getting power to the ecu. With the stock ecu plugged in I get switched 12v as I should to pins 49 and 59 and the fuel pump primes etc etc. When the AEM is plugged in, no relays click and there is no 12v power to the pins previously mentioned. Does anyone know why this would be happening? I am trying to load the basemap file to the ecu but cannot communicate with it unless it gets power. I have tested the ecu plug and I am getting power and ground everywhere else I should be. My thought is that there is no basemap file on the ecu, therefore it has nothing to switch the relay thru pin 16 and supply power to the ecu, can anyone confirm this or provide any other insight? It is the plug and play series 2 AEM for the rb25.
