HPF Chrisk wrote:why are you guys changing from 5w 30 to 10w 30? i just got me a case today of eneos 5w 30 for my next oil change, should i run the eneos or go with redline or what do you guys recomend and what weight to?
the FSM recommends 7.5w30, which i'm guessing is between a 5w30 and a 10w30. Pointless to run more than 10w30 on a stock block unless you're seriously tracking it and heating the oil a lot. There's a thing called too much oil pressure too. Most people on here have barely modded to stock motors, so really anything above 10w30 is too thick IMO.
Of course if your motor is built and you have looser clearances then sure you can run thicker oil. If you're running big boost and really taxing the motor then you might want thicker oil too.
