+1cdorhout wrote:It may be cheap, depending on why the head is off the motor. I doubt he just took the head off for no reason. Find out what's wrong with the motor, and see how much money you have to drop to get it running again, then you'll know if it's cheap or not.
I know the guy selling the car and i saw the car running before it was taken apart. I know the bottom end is in good condition. I just dont know if it worth $4000 taken apart, Thats what i am trying to find out. What is the cheapest i can find a car like this but running. I figure if i buy the car i need about $1000 to get it running, So i would have $5000 in the car.jrb92se wrote:ive seen cams for rb's for sale on alot of sites try nengun.com first. prolly gonna run you about 500.00, and you dont know what really happened to that engine, like how did they damage the cams/ blow the stock h/g does it have rod knock, are the rods/bearings straight. sounds to me like you may be buying someone elses 4000.00 headache.
did you not read! he said the cams are missing.FriedEGs wrote:cam's are damaged? you better check the valvetrain for damage..might be cheaper/easier to just find a low mileage head...
Uh, I did read.. thanks!!!! obvoiusly YOU did NOT!!!BoostsFed wrote:did you not read! he said the cams are missing.
pwrdbypsi wrote: The car has been apart for about a year and the cams are damaged. So i would need to buy some cams and a gasket kit to put it back together.
