Ok since my name is getting thrown in here I'll chime in
First, I've never heard of anyone eliminating the knock sensors on the RB motors mostly because they are a good indicator to use for tuning. I am unsure of why it would affect your base timing either. I would start by putting the knock sensor harness back to stock and eliminating the resistors.
Second, having the CAS turned all the way one direction to get the base timing to 15* BTDC is very common. I think it could be due to the PTU (power transistor unit) = ignitor because my base timing changed when I went to LS2 coils and eliminated the ignitor. Now my CAS is set in the middle. Anyway, don't worry about the CAS position as long as the engine is warm when you set the timing and you can get it to 15*.
Third, the plugs should not have much of an effect on the engine breaking up especially at the boost the car is at. I would suspect the coils before the plugs.
How do you know the MAF is at 4.8V at WOT? Do you have a wideband O2?
For the record, I knew I had a bad fuel injector because my wideband started showing lean (16+ at idle). I don't know if it was breaking up up top because I did not push it when I recognized there was something awry. I tested spark and it was fine so it had to be fuel related. The injector didn't have continuity between the two pins which meant it was burnt up.
