By spirited driving he means passing 60! Trust me this car gets treated very gently and pondered your right the car is located in Atlanta. Personally I think the car is just acting out because it's owner let it lose to a stock rb25 running on only 5 cylinders! Lol seriously though hopefully someone on here can help him get this overheating thing fixed so he can try to redeem himself. And no the car wasn't overheating when he got whipped.Cjmartz2k wrote:The thermostat 100% will not help you. Do you have these problems at high speed beating on it, or just low speed drift or parking lot kind of racing. A/C will make the problem much worse BTW.
I guess its just the slight buffer, doesn't make sense to me either but its working great! I'll be adding A/C to the mix as well here really soon as well. I could not have bled it better either and there is not way to install the thermostat backwards. Like I said, my previous RB's where the same exact way and they where cured the same exact way...I just didn't remember the part number for the thermostat.Cjmartz2k wrote:I'm glad you got it fixed, but I have to say that makes no sense. All the lower temp T-stat does is start to open 10* earlier. Both T-stats would be wide open by 200* and do exactly the same for cooling. In theory the fact that the 160* opens earlier gives you a little more buffer time until it would start over heating, but the end result would be the same. I'm baffled. Honestly, the only excuse I can come up with is maybe you bled it better after this t-stat install--or you had a bum t-stat to begin with. It's not possible to install RB T-stats upside down, is it?
I've been a tech for years..I would hope I know how to install a thermostat..lolmrflip69 wrote:maybe it was installed upside down? (jiggle valve)
lol...I'm talking about when the car is running cooler, not when its cooler outside. Yea it runs real good when its cold outside but its running even better it seems when its running alot cooler.l0nestar wrote:Cool air == more dense. No, it is not your imagination.
I'm pretty sure he meant the same /\/\Krazykouki wrote:lol...I'm talking about when the car is running cooler, not when its cooler outside. Yea it runs real good when its cold outside but its running even better it seems when its running alot cooler.l0nestar wrote:Cool air == more dense. No, it is not your imagination.
