The RB24DET conversion is more for people who already havea a RB20DET in their current car which is mainly a skyline.. and do not want to go through the trouble of swapping an engine or have higher insurance.
For 2.4 you'd have to source a RB26DETT crank and also the larger pistons along with using RB26 connecting rods for the added strength or aftermarket ones.
For 2.2 you just have to use the bigger pistons 82mm and you don't have to mess around with fitting the crank and rods.You can use Tomei forged ones or custom made. Also you can use forged 4AGZE which are also 82mm.
http://www.tomei-p.co.jp/webcatalog/piston4.html
If you want to move the redline up, you're going to do the obviouse of head/valve train work aka stiffer springs also use some RB26 bearings.
RB24DET without much tunning will do 300 RWHP and of course you have to upgrade the fueling. With a T04E turbo, GTR intercooler, you can do 500+HP.
The RB26 crank is not a direct fit, it needs a little modification to the block which is estimated at 3-4mm at the bore bottoms to clear the crankshaft. I would recommend buying an aftermarket engine managment like the SDS is pretty good & cheap.
http://www.sdsefi.com
If you haven't bought the engine yet, I would purchase a RB25DET and then throw in the RB26 crank, rods, pistons. The RB25 has a way better flowing head and the piston walls will not be so thin because of the overbore like the RB24 conversion.
